Preselection counter mechanic failure
frpe12
Beitrag von frpe12 »
Hi all,
On my TS1000, autostop feature does not work with the preselection counter.
The issue seems mechanical, as when I activate the electrical switch manually, it stops perfectly.
But the small plastic piece that pushes on the switch does not move at all when the preselection and counter values match.
Do you have some tips about this problem ?
Thanks.
François
Re: Preselection counter mechanic failure
Few years ago i dived the whole counter in WD40 for several hours and played with the mechanic.
Until the counter works as it should. Maybe this works too?
Maybe i have a counter in Stock? Probably the last.......
frpe12
Hi Mampfi,
I'm going to follow your advice !
I only sprayed some WD40 on it, but maybe not enough !
I'll let you know.
Regards
François
Zurück zu „TS 1000“
