Playback equalizer calibration
frpe12
Beitrag von frpe12 »
Hi all,
I searched in the different topics, but couldn't find any post about playback equalizer calibration, using R13 and R14 trimmers on board G.
Could someone explain how to proceed for the different speeds ?
Thanks to all.
Re: Playback equalizer calibration
The R13 and R14 trimmers on board G are used to adjust the equalisation for the 19 kHz speed in accordance with the standard.
The equalisation settings for the other speeds are switched via this setting using fixed values.
A measurement tape recorded in accordance with the standard, with a frequency response of up to 20 kHz at -20 dB, is required for this adjustment.
frpe12
Hi Mampfi,
Thanks for your quick answer.
Ok, so I just need to adjust the trimmers to get the expected level of the reference tape. Right ?
Kind regards
No, the trimmers 13 & 14 (the upper ones) are for playback frequency response only.
If you want to adjust the reproduce level, you have to use the trimmers 53 & 54. (The lower ones of board G)
frpe12
Yes, I was referring to R13 and R14 for frequency response. What is the procedure to adjust them ?
I already adjust R53 and R54.
Ok, understood. -for adjust R13/14 you need a NAB frequency response alignment tape.
frpe12
Yes, that should be working.
Set the 16kHz to the same level as 1khz.
But first adjust the azimuth with the 10kHz section and the playback level
Zurück zu „TS 1000“
