netzteil TS1000
Andre Van dael
netzteil TS1000
Beitrag von Andre Van dael »
Hi, problem with my TS1000 : When switching on, the 2 discs are turning in oppostie direction;
No other functions , no lights in VU meter and switches.
I found on internet that this is probably the ' netzteil circuitboard , the ' sicherung' 4 is broken .
Can sombody help with reparation , or info about buying a new circuitboard ?
My electronic knowledge is limited, mechanical is ok, so replacing the circuit is doable
thanks in advance
PS I am from Belgium ( Limburg)
Re: netzteil TS1000
This is the general known issue about the TS1000 powersupply.
For shure there is IC1 = fixed voltage regulator 24V and C18 = 1µF Tantal Condenser is broken.
Andre Van dael
Re: netzteil TS1000
Hi, thanks for feedback.
I will try to find the spare parts, do I have enough with the description you gave ?
another ( stupid) question : how do I dissasemble the " cooling plate ? I don't see any screws , is this glued ?
Re: netzteil TS1000
Andre Van dael hat geschrieben: Mi 21. Aug 2024, 19:39 I don't see any screws , is this glued ?
No, you can find 3 Philips Screws on the Top of the TS 1000, where the heatsink is located.
Zurück zu „TS 1000“
